on 11-01-2023 02:24 AM
I’m in Athens and can’t get Wi-Fi when I’m out
on 11-01-2023 07:52 AM
@Hartd1 : I think you are asking for the wrong thing. EE don't supply you with WiFi connections abroad. You get those from WiFi hotspots either in your hotel or at like Internet cafes out & about. I think you mean you can't get a mobile signal there.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
