20-02-2024 11:12 PM
Hi all, i have a galaxy s23+ but its not showing wifi calling, either on my data, my home wifi (BT) or any wifi i get.
Thanks all.
21-02-2024 08:38 AM
Hi @Reesy71
If you go into Settings, Connections, WiFi and WiFi Calling, are they both turned on?
If so, can you turn both off and restart the phone and then back on again to see if this helps get you connected to the WiFi network?
Leanne 🙂
21-02-2024 10:04 AM
21-02-2024 11:57 AM
Hi @Reesy71
Where did you purchase the device?
Are you using a pay as you go or pay monthly SIM?
Leanne 🙂
21-02-2024 03:34 PM
21-02-2024 03:40 PM
Thanks @Reesy71
I would advise calling us on 150 and selecting technical support, our tech guides will get this looked into for you.
Leanne 🙂
