WiFi calling is not working
akatsoulis
Hello my WiFi calling is not working. If I put my phone on airplane mode and switch on the WiFi on, I can’t make any calls. Anyone is having the same problem?
Northerner
Hi @akatsoulis
What device do you have? Are you in EE PAYG or pay monthly contract?
Have you tried restarting your device?
Christopher_G
Hi @akatsoulis
Is it working any better after restarting this morning?
No is still the same.  I have rebooted the phone, I have turned on and off the WiFi calling, the airplane mode but nothing
Christopher_G
Thanks, @akatsoulis.
I would recommend speaking to our Technical Support team so they can check everything from our side.
Is this problem evident on more than one WiFi hotspot/router?
Or specific to one?
