on 07-10-2023 03:31 PM
I'm in America, and I have a roaming pass. But I can only text, not call. I have a basic 4g Nokia and there is a white triangle on the top left of the screen. I have a sim-only plan and don't use any data. EE says I can use my usual plan but I can't make calls, only send texts. Any help would be amazing!
on 08-10-2023 03:55 PM
Hi @Cmarti87
I am sorry to hear this.
Could you try your SIM card in your friends phone to see if you can make calls?
on 08-10-2023 04:32 PM
The swap of SIM will prove what I suspect here, this is a device-issue.
The US networks require a phone to support VoLTE, which is the technical standard behind 4G-calling. I suspect you are in a location where there is no 2G or 3G coverage, and only a 4G service is available. The Nokia 105 is connected to that 4G network, evidenced by text messages working.
But the phone needs to support 4G-voice-calling for you to make or receive calls. A quick search of the Nokia spec sheet confirms this phone has VoLTE-support, but clearly your symptoms are suggesting there is something awry.
