Which settings for use abroad
TiffanyS
I have just added Roam Further to my account. If I want to make or receive calls which settings do I need to use?
For example I don't want to turn on data roaming if I don't need that for calls and texts. I have an Android phone.
I tried to make a call today and couldn't get through to the number and they couldn't call me.
You don't need data roaming to make calls or texts. However if you are unable to make them it is likely that your EE a/c settings, not phone settings, need adjusting.
As  you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
