Watch 6 classic keeps popping EE plan set up on my phone every few hours..
carguy143
Hi. Not sure where best to post this but I bought an S23 Ultra and Watch 6 Classic (LTE) on 27th December. After installing all updates I set up the watch and mobile plan which is working just fine. I can send and receive texts and make calls on my watch without issue using the mobile network. For some reason though, I keep getting the above notification every few hours.
EE support via X have confirmed everything appears to be correctly set up on EE's side.
Anyone else getting the same?
James_B
EE Community Manager
Hi @carguy143,
As this notification is pushed to your Watch from the Galaxy Wearable app, Samsung may be best placed to trouble shoot this for you.
Have you reached out to their support team?
carguy143
Yeah. I've reached out to Samsung directly via the Members app and await
their reply. It seems others on Reddit have this issue but the only mention
I've seen refer to EE so figured I'd kill two birds with one stone.
James_B
Hopefully they'll get back to you with a solution soon, @carguy143 🙂
