29-04-2022 01:30 PM
Hi there,
Since Monday 25/04 I have had an on-off message popping around 6 to 8 times a day saying "Could not activate mobile data network. PDP authentication failure".
It happens very randomly, like in waves. I have tried all support I have found online:
Nothing seems to work and after a few hours (or minutes), I get the annoying message again.
Details of interest:
I tried contacting EE CS, but after literally hours first waiting on the chat, then trying to explain the issue I was cut off instead of moved to the tech team (as confirmed) so ....
Hopefully someone can help before I gain the strength to contact CS again.
Thank you!
29-04-2022 02:13 PM
Hi @20212_q
You need a new SIM.
You can get one online and wait for it to be posted (your existing SIM will be deactivated) or you can go into an EE store and set one up for free (best option)
If it keeps happening after that then it's your device.
22-06-2022 01:21 PM
Can you explain why a new SIM would be required?
I have started having the same issue and I have only had my SIM for 6 months.
22-06-2022 01:27 PM
its happening to me just now too. Could there be an EE issue just now?
22-06-2022 01:35 PM
That might be the case. There are a lot of people reporting issues on Twitter and Down Detector has seen a spike.
https://downdetector.co.uk/status/ee-everything-everywhere/
22-06-2022 01:38 PM
Hello, my Samsung S21 won't connect to mobile data, ive tried turning mobile data on and off, changing it to just 3g, and reset the phone multiple times but i am not getting mobile data.
and I have tried phoning EE but no-one is able to take the call 😂
22-06-2022 02:04 PM
And me too!
22-06-2022 02:04 PM
I'm having the same problem. Message popped up on my phone saying
"No mobile data. Temporarily turned off by your operator for sim 1"
No warning or explanation or anything
22-06-2022 02:10 PM - edited 22-06-2022 02:18 PM
22-06-2022 02:14 PM
Only getting 3G
no 4 g or 5g
just went to 3 g
