Voicemail
Jmartinc
 I have a voicemail unlike any I have received before. Is it a scam?
@Jmartinc  that’s not a voicemail that so you can call and listen to your voicemails.
as your using a iPhone you can use visual voicemail.   Just text iPhone visual to 150.  Then you’ll see a list of your voicemails when you get them and you don’t have to listen to them one at a time if you get more than one voicemail.
