23-12-2022
02:35 PM
- last edited on
23-12-2022
03:36 PM
DanielPA
I forgotten My PIN number. Any advice would be appreciated. I need help to set up a new one. Thanks
24-05-2023 02:41 PM
Thanks @williamowusuadj
If you select account queries the team can look into the voicemail for you.
24-05-2023 03:13 PM
That option is not there.
24-05-2023 03:31 PM - edited 24-05-2023 03:33 PM
Please try calling 150 then option 2 then 1 for mobile, then tech queries. You will get a text please complete the information required including you are unable to access the voicemail as the PIN needs reset, and a member of the team will get in touch.
We have no access on the community to get this done for you, you will need to speak to the tech team.
20-07-2023 03:46 PM
I have tried every combination to try and speak to someone . My fault that I put in wrong code. I am an on call health worker!!! I have filled in a text and sent it off
20-07-2023 03:47 PM
Now done - thanks
20-07-2023 04:00 PM
Has this been sorted for you? @elfis
Leanne 🙂
01-09-2023 02:51 PM
Hi
How did you resolve the lost Pin number problem?
01-09-2023 03:38 PM
To get this resolved please call us on 150 and the team can reset the voicemail PIN for you.
Leanne 🙂
