02-08-2022 04:30 PM
For the last 24 hours my voicemail is under maintenance, how long will this last?
is anyone else getting the same problem?
02-08-2022 05:17 PM
Hi @Dax67
Thanks for coming here 🙂
Can people leave you a voicemail?
Is this when you call the voicemail you hear this message?
Speak soon.
02-08-2022 05:24 PM
Voicemail is working fine for several users here, so there's certainly no national outage.
As per the post above this one, is this on calls you're making to VM or calls you receive?
02-08-2022 06:06 PM
I have called my phone and when I try and access voicemail I get the same response. Voicemail is currently under maintenance
or word to that affect.
02-08-2022 06:07 PM
Both
02-08-2022 06:11 PM
02-08-2022 06:14 PM
Yes. I turned it on via text to 150.
I’m in the U.K.
02-08-2022 06:15 PM
Thanks @Dax67
Has this worked since you text 150 to activate the voicemail?
Which phone are you using?
02-08-2022 06:20 PM
Doesn’t matter if I switch the VM on or off. I still get the same message.
iphone XS
02-08-2022 06:27 PM
