09-03-2022 10:16 PM
My voicemail does not work and never has.
I have searched for and attempted apparent fixes to no avail.
If I call 150 and select to turn VM on, nothing. If I text 150 with VM ON I get the following response:
Sorry, we're having some trouble completing your request at the moment. Please try again later.
If I try to reset by texting VM OFF and reboot, I get that same response.
I have had this same response every time I've tried for months so "please trying again later" clearly isn't the issue.
Can anyone recommend trying anything else?
Many thanks.
09-03-2022 10:20 PM
Hi @wk16491
What happens if you try calling voicemail? Either by 222 or speed-dial 1?
You may need to call EE C/S and speak to an agent - rather than using any automated services as it sounds like you have so far.
10-03-2022 01:32 PM
Hi bristolian,
Thanks very much for taking the time to respond.
When I call 222 I get the normal message that tells me about my voicemail options and it tells me I don't have any messages. Nothing seems wrong here. But if anyone calls me and I don't answer the phone rings and rings and then just cuts out without option to leave a message.
I will contact customer care directly.
Thanks again!
10-03-2022 03:21 PM
