Using phone while abroad
Chadfisher
Hi , I’m currently in the Maldives . I am not receiving any calls from the U.K. . Can you help ?
Northerner
Hi @Chadfisher
Is roaming and international calls activated on your account?
If not you'll need to download Skype and call EE using the number in my signature over WiFi.
@Chadfisher : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Is your issue, purely that you can't receive incoming calls? Or that you can't receive any calls or text messages?
Does your phone show a connection to any local networks? Lack of network coverage - if that is the problem - would affect all services that need it. Making or receiving calls, sending or receiving text messages, or using mobile data, would all be a consequence.
