Using phone in Lanzarote
Millieteigann
Hi all,  If I go to Lanzarote can I add on my abroad roaming pass for £15 and use my phone as normal?
@Millieteigann  Yes you can.   Don’t forget the pass only allows to you use your allowances it doesn’t enable roaming on your account.   You need to text ROAMING to 150 in order to do this.   Do this now as having this enabled will not cost you anything and it’s worth having it enabled anyway.
