Using mobile abroad
ozevans
I am in Greece and cannot make or receive calls. I have turned on roaming and changed my cap and texted 150 but no luck.
ozevans
I am in Greece and my mobile is not allowing me to make calls or accept calls. I have got roaming on and texted EE on 150.
Christopher_G
Hi @ozevans
Welcome to the community. I hope you're having a lovely time in Greece.
Is your SIM card pay as you go, or pay monthly contract?
Monthly contract.
Christopher_G
@ozevans : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
