Calls not working abroad even tho i have roaming
Shabbylibrarian
So they worked when i went through Belgium, germany, czech, poland but not now that i am back in czech. I did not get a welcome text like before. I cannot ring the helpline as i can't make calls. The digital chatbot does not appear.
11 REPLIES 11
Christopher_G
Hi @Shabbylibrarian
Welcome to the community.
Have you tried restarting your device or manually searching for a network?
Hi chris,
Thanks for responding,
Yep restarted it a few times. I can send texts. Its only when calling it wont work. It says mobile network not found.
I also tried using a different APN.
Christopher_G
Thanks @Shabbylibrarian.
Could you check to make sure that international calling and roaming are still activated in your My EE account please?
Hi Chris, They were blocked. When i tried to unblock them they said i couldnt and to text info to 150. I did this but nothing seemed relevant. I have texted roaming to 150. (I had done this when first leaving the country).
I now had a text saying i was set up for roaming in any country.
Christopher_G
Could you try restarting your phone now to see if it connects and works, @Shabbylibrarian?
Hi Chris,
Done. And it still doesnt work.
Christopher_G
OK, thank you, @Shabbylibrarian.
I would suggest speaking to our Mobile Care team. A lot of people in this situation use Skype and other VoiP services to contact us from abroad on +44800 0798586
Hopefully they can get this fixed for you.
Chris,
I dont have skype is there no way we can email?
