No signal
Mickey296
I am from the UK and just arrived in Florida. I am unable to make calls or texts from my phone. I have checked that all settings are correct but still unable to access these services. I do not have the option to text 150 as a result of this. Please can someone contact me to resolve this issue.
@Mickey296 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Thank you for your reply. I have tried what you suggested with no success.
I am still being advised to contact 150. I did not register for roaming
prior to leaving the UK, as I wasn’t aware that was a requirement due to
never having to register before.
Thank you for your help. I am guessing my only option now is to call
customer service?
Yes, over Skype if you have no other means.
