17-06-2023 08:27 AM
Still can use only on ai-fi on holiday in italy
very inconvenient
so far: enabled roaming on my iPhone, sent message roaming to 150, reply to their security queries, send the message to increase the cap …
17-06-2023 08:47 AM
Hi @Gb1970it
Thanks for posting.
Do you have a pay as you go or pay monthly account?
Do you have signal showing on your device?
Leanne 🙂
17-06-2023 08:58 AM
@Gb1970it You say you’ve sent a message to 150. What’s your issue again as that message to 150 is a text message so obviously you can send texts.
17-06-2023 10:29 AM
Roaming isn't something you enable using your phone's menus, it's a network level setting that is activated by texting ROAMING to 150 before leaving the UK. Did you do this?
If you did so, and your phone shows a local network connection, then roaming is activated. What do you mean by "reply to their security queries"?
