Abroad in the US, can't call or text 150
abeech216
I'm abroad in the States and I have a contract with EE that includes roaming. I am able to use data but I can't send or receive texts or calls, including to 150. I have tried turning the phone on and off, as well as switching the network selection.
6 REPLIES 6
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
I called over Skype. My phone is already set up for roaming. I'm still having the same issues
Lesley_W
Hi @abeech216
Welcome to our community.
When you called, did our team run through any troubleshooting with you?
Lesley
Northerner
Hi @abeech216
What device.
Are you using the correct country codes such as +44.
Did you receive a welcome text message on first arrival? It's as much part of "is my roaming work" as it is the gateway to choosing billing add-ons.
If you haven't, I'd next question whether you're using mobile data or WiFi. Which leads onto whether your roaming facility is actually working.
Interesting I also have just returned from the USA today and over the last few days I’ve been unable to make calls back to the UK, the call would ring the UK number but as soon as the line was picked up, I got a call failed?
Same issue with incoming from the UK, as soon as I answered again call failed.
I did receive the text message welcome to USA
Hi from EE, welcome to The United States of America.
While you're here, thanks to your Roaming Pass you can use your UK plan allowances.
Calls to countries other than here or the UK are £1.66 per min and texts 76p each. Other charges are the same as when you're in the UK.
For more information on roaming, monitoring usage and managing spend and how to avoid unexpected charges: https://ee.co.uk/help/mobile/roaming
If you have a spend cap on your account, please note that many roaming charges count towards it. If it hits zero, we'll block roaming service to prevent any unwanted charges. If you're the account holder you can check your spend cap by logging into the EE app or texting SPEND CAP to 150.
Call +447953966250 for Customer Services or 112 in case of emergency.
Have a good trip!
