Use abroad
Betsleigh1
No Internet in france after installing in UK
Jon_K
Former EE Employee
Hi @Betsleigh1.
Welcome to the community.
Is roaming enabled in your My EE Account?
Do you have a signal on the phone?
Jon
@Betsleigh1 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
