Re: Roaming Blocked
Doctortme
Going nuts with “Enable roaming “ button greyed out on phone, says working on iPad Ee “manage my account”
when I uncheck on phone says somethings gone wrong, phone 150
CS unable to sort
help!
Leanne_T
Hi @Doctortme
When called us on 150, was roaming set up for you on the account?
Thanks.
@Doctortme : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
