Turkey roaming not working
Lucindamann
I am in turkey and need data for 24hours but it doesn’t seem to work. Please help asap
Katie_J
Hi @Lucindamann
Welcome to the EE Community.
What is happening when you try to use your data?
Did you activate roaming before leaving the UK?
Katie
Hello,
I thought it was already activated, but I cannot access anything. Did not
received a welcome text when arrived. Just no service appears.
Thanks,
Lucinda
Katie_J
Hi @Lucindamann
I'd recommend checking you have roaming active on your account.
You can check this via our Live Chat team, a link for chat can be found in the EE app under 'Help'.
Katie
@Lucindamann : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
