Transfer calls from my mobile EE to a landline Virgin
Dixmastro77
 Good evening guys I wanted to know if any of you knew if you could use a call transfer from my EE mobile to a Virgin landline. Unfortunately, I moved to a place where there is no telephone coverage and I only have Virgin's broadband. I need to be always reachable by my clients! Can I divert the calls that I will unfortunately not be able to receive on my mobile EE, to a Virgin landline?
You can either use call divert, or - if that Virgin broadband has a WiFi-router, use WiFi-calling.
WiFi-calling allows you to use your mobile phone entirely as normal - making & receiving calls, sending & receiving texts - without needing mobile network coverage.
Call diverts will only allow you to receive calls if the Virgin broadband router doesn't have WiFi.
@Dixmastro77 : You may divert your calls made to your mobile to any phone no. you choose, be it a mobile no. or a landline no.
