Thailand
Sharon149
Hi
I’m currently in Thailand. I’ve just added roaming to receive text from UK but I’m unable up send or receive any UK text. My UK sim is currently in my sim.
How do I receive texts?
What you mean by "added roaming"? In what way?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
To receive texts or make/receive calls abroad, you need a mobile network connection which is unlocked by enabling roaming.
Does your phone show a connection to any Thai networks? If not, that's why you can't receive texts.
