‎05-09-2024 11:53 AM
I have 'unlimited spend cap' set up on my mobile, but EE is refusing to send SMS texts as it says I have exceeded the cap. Anyone else experienced this? I have tried to talk to EE - but no luck so far!!!!
‎05-09-2024 06:25 PM
@bsgbsg Sorry I thought you had meant you got through to speak to someone on 150, it will need someone to take a look at your account to help resolve this.
So when calling 150, if you press option 1 you will get sent a link by text and you should select, Mobile>Tech support> Network Problems.
You will then get a text come through where the system checks your postcode for issues, when none are found reply NETWORK and then the next text will offer you a call back within 15 minutes when you text FAULT ADVISOR.
Alternatively if you would prefer to avoid the visual menu, call 150 and select option 2 to use the traditional audio menu and select the option for technical support to get connected to one of our guides.
Alex
‎05-09-2024 01:17 PM
How is "it" saying that you have exceeded the cap, when you send a text message? Are these standard texts to 07xxx mobile numbers?
‎05-09-2024 02:08 PM
‎05-09-2024 05:16 PM
Hi @bsgbsg,
Welcome to the EE Community 🙂
Are these just standard SMS texts you are trying to send to UK mobile numbers as @bristolian mentioned? Rather than texts to a short code number for example?
Is it effecting every number you try and text currently? What did they say when you called and spoke to us on 150?
Alex
‎05-09-2024 05:49 PM
The text are normal and being sent to another mobile number - nothing special.
The 150 number gave the text response I mentioned above - I answered the automated questions that 150 prompts you with and the system got me to the 'cap' part of the system which then cleverly sent me a text and hung up. Not a very helpful response! I never got the chance to talk to a human.
Alex
‎05-09-2024 06:52 PM
‎25-10-2024 08:28 AM
Yes I'm getting it as well
‎25-10-2024 08:31 AM
I'm getting same response.im trying to contact ee but going around in circles I can't use mobile at all.
‎25-10-2024 08:34 AM
I can't speak to anyone I just keep getting sent around to different sections of ee website
