26-09-2022 08:00 AM
I have an EE card I am in Cyprus and it’s not letting me make phone calls what is the problem
26-09-2022 09:06 AM
@Leonnikos Are a contract or PAYG customer?
If you are a contract customer have you enabled roaming from within your online account? If you open the my EE app and click MOBILE PLAN then scroll to the bottom and click SETTINGS you’ll see the option to enable roaming.
26-09-2022 10:08 AM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
