Blocked calls
Clarkie1988
I’m currently in Bali, Indonesia and if I try to make a call I’m diverted to what seems like a local automated service which tells me my number has been blocked????
@Clarkie1988 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Have you been able to use your phone internationally before?
If yes - try restarting your phone and also manually selecting a different network
If no - refer to the advice posted above,
