Sending SMS delayed and calls connecting delayed - EE UK
Profile closed
Not applicable
I've got my EE SIM in a Samsung A53 5G that I use for business
Connecting calls can take around 30 seconds and sometimes, when sending an SMS, it takes a good 20 seconds to send also (I use Textra and have the notification for sent messages)
FYI this happens on the native SMS app also; so it's not Textra related
The texts do get through 9as do the calls); but I cannot figure out why the delay all the time
Phone reset, all apps/OS is up to date etc...
It's only happened with EE; GiffGaff & Three before that had zero issues
Any thoughts/suggestions?
Cheers
11 REPLIES 11
Katie_J
Good afternoon @Profile closed.
Does this happen in multiple locations?
Have you tried another SIM in your device to see if this works OK?
Katie
Call setup times can vary substantially depending on whether the calling and called party are on an IMS-layer (VoLTE/WiFi-calling) or legacy (2G/3G) or by extension, other networks.
Mobile originated text submission is similar.
Profile closed
Not applicable
Thanks Katie
As said; zero issues with GG or Three SIMs; it's only since I've moved to EE that this happens on my Samsung
Zero issues on my iPhone 14 PM (also on EE)
Re my business mobile; I work from home, so it never leaves the house TBH
Profile closed
Not applicable
It's the same whether on 5G, 5G with VoLTE calling and wifi etc...
I've tried all sorts of settings, things on and off etc; still the same issue
Katie_J
My apologies @Profile closed I have read the ending of your original post wrong.
Are you aware of any issues within your area?
This can be checked using the Network Checker.
Katie
As previously mentioned, call setup times are not dictated by any phone settings and it's not something users have any preference over.
Calls will generally setup quicker when both the calling & called parties are on IMS-layers, but as long as the call completes there should be no cause for concern.
Profile closed
Not applicable
Hi Katie
Zero issues
Profile closed
Not applicable
Makes no sense
Never had this issue before until I've moved to EE.
And it is a concern (more an annoyance) as I use my phone A LOT as its my business number.
So making calls and constantly getting delays once I've dialled is getting infuriating now...
If it is happening on your Samsung but not the iPhone maybe it is time to swap phones?
Are both using 5G sims?
