Roaming
Kerryhayhurst
My son is in Spain but having issues with his internet  on his phone, yet roaming is on any advice
@Kerryhayhurst : Can he make calls & texts?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
What are the issues with your son's Internet?
Only one reply is necessary, with all answers.
