Roaming
Faz23
Hi how can I add roaming to my account, I’m in Sri Lanka. Please help me to activate my data roaming. Thank you
Data roaming is a phone setting which merely allows the use of mobile data whilst roaming.
Roaming is an account-setting which enables access to foreign networks and is thus crucial to having coverage abroad. If you're on PAYG, this is auto-enabled on first use in the UK.
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/srilanka.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have used your PAYG SIM to make a call or text in the UK.
