Roaming
JoBHill
I am in Spain and have sent a text to 150 to set roaming, I've had a response to say this has been done. However, in my online account it says that roaming is blocked and I can't change this. I can't make any local calls, my phone says that its calling but they is no dialling tone and I have a message saying 'conditional call forwarding active'. Can anyone help?
JoBHill
Thanks for the helpful messages. I eventually got the issue sorted using the messaging facility on the website.
7 REPLIES 7
Schockwave
Hello @JoBHill ,
Welcome to the community,
If you are not able to activate roaming via your account, you will have to ring customer service via other means. If you have Skype there is a free number to ring:
https://ee.co.uk/contact-ee/account-billing/mobile
You also need to make sure that call abroad and premium calls are enabled.
JoBHill
Thank you for your reply.  I can't find the Skype number following the link, can you direct me?
@JoBHill , you need to ring one of the 0800 numbers , but put +44 in front: +448009566000.
JoBHill
Leanne_T
Thanks for letting us know @JoBHill
