Roaming bought £10 for USA doesn’t work here
Elephantinthe
Help I bought roaming pass for USA and also for my daughters. Theirs work beautifully. Mine will do nothing it won’t connect with providers over here. I’ve struggled with it all day hotspotting if there’s etc.
@Elephantinthe : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Elephantinthe
You are awesome! Only you solved this with your reply. Not EE not Apple not my family and Friends. I thank you.
Elephantinthe
Specifically it was this bit that solved the problem;
Christopher_G
Glad to hear that @XRaySpeX's help got you up and running, @Elephantinthe.
Enjoy the rest of your trip. 🙂
