on 15-08-2022 06:27 AM
I have roaming on but unable to make calls and have no service unless I’m the hotel?
on 15-08-2022 06:29 AM
I have roaming on but I am unable to make calls also only have service whilst in the hotel. I have checked settings, iPhone 13 mini
on 15-08-2022 06:31 AM
on 15-08-2022 07:12 AM
@NCY : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
on 15-08-2022 08:26 AM
Hi @NCY.
Do you have signal in the hotel or is it WiFi you're connecting to?
Is Roaming active in your My EE Account?
Jon
