Hi, I am on roaming and I try to activate the voicemail, not working
AnaKiss
I texted VM On to 150, I received the confirmation , i set up the message , but the calls are not going to the voicemail. Even with the phone off the phone is ringing. What I should do for the voicemail to work ? Thank you
Jon_K
Former EE Employee
Thanks @AnaKiss.
I'd recommend getting in touch with our Customer care team so they can check your account and help you get voicemail set up.
Jon
@AnaKiss : Try texting VM OFF then turn off/on the device and then try VM ON.
Did that as well , not working 😞
Jon_K
Former EE Employee
Hi @AnaKiss.
Do the calls go to voicemail after ringing, or just ring out?
Jon
Hello Jon, just ring out . It' s not going to voicemail at all ! Thanks
Jon_K
Former EE Employee
Thanks @AnaKiss.
Jon
