Roaming
Aleksander2
Hello, I registered with you on the web, everything has been confirmed. unfortunately I cannot make calls or use the internet.
Leanne_T
Hi @Aleksander2
Thanks for coming here.
Are you with us on pay as you go or pay monthly?
Leanne 🙂
@Aleksander2 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
