Roaming
Yasmina2022
I have roaming package and I cannot make/receive calls / texts to from the UK. What could be the problem. Any suggestions please?
7 REPLIES 7
Leanne_T
Hi there @Yasmina2022
Thanks for coming here.
Do you have a pay as you go or pay monthly account?
Leanne 🙂
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Thank you for quick your response. I rebooted the phone when I got the new
roaming package. I don't know what to do as there's no way I can contact EE?
Regards
Yasmina
Thanks Leanne, I have a contact ' pay monthly account
Yasmina
Why not? I told you how to contact EE over Skype.
I tried and I could not retrieve verification number from my phone .... due
to the problem im having
Jon_K
Former EE Employee
Hi @Yasmina2022.
Do you have a signal on the phone?
What phone are you using?
Jon
