on 01-08-2022 09:42 PM
Hi, I can’t connect to a network either. I have tried all the steps and made sure roaming was on. I cannot text / call to find out what the problem is. Please can you help? Thanks
on 01-08-2022 09:43 PM
Hi, all these steps are not working for me either and I need to be able to be able to at least receive texts. Thanks
on 01-08-2022 09:49 PM
@nslow25 : If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
on 01-08-2022 09:51 PM
@XRaySpeX thanks, how do I call via Skype?
on 01-08-2022 10:06 PM
@nslow25 : By installing the Skype app somewhere & registering to it.
on 01-08-2022 10:27 PM
Thank you very much !!
