Roaming
Ryan1301
ive got roaming included in my smart benefits. I’m in Mexico now and I’m recieving texts but internet does not work outside of wifi connection
Christopher_G
Hi @Ryan1301
Welcome to the community.
What kind of phone are you using? Is data roaming switched on within your phone settings?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
_MrR_
Scholarly Contributor
It looks like this could be more a handset setting issue rather than a problem with roaming.
This is because you've said you can receive texts meaning the phone's hooked up to a network in Mexico. If you didn't have roaming service, you wouldn't connect to the network.
As it's only data that isn't working, it'd be worth checking the settings menu on your device to check data roaming is activate (a lot of manufactures have this set to off by default to prevent unwanted charges)
