11-03-2022 12:45 PM
Hello,
I am now in Croatia. My iPhone 2020 SE permits international calls and works fine when I dial a Croatian landline.
However, it will not connect to a Croatian mobile number. I have checked that the Croatian mobile number is valid (by dialling from a Croatian landline).
Regards
11-03-2022 01:51 PM
@gvs1 Have you enable on the iPhone in settings > phone > Dial Assist ?
12-03-2022 04:23 PM
Yes, dial assist is enabled and my phone (iPhone SE 2020) has no problem reaching a Croatian landline with the same international code. But it fails to connect (either SMS or voice) to Croatian mobiles.
I have had the "receiving" mobile phone checked and it receives calls from Croatian landlines. Also my daughter in England successfully sent a text message to this "receiving" Croatian mobile so I don't think there's any problem with the Croatian end.
13-03-2022 08:16 AM
Hi @gvs1,
What happens when you try to call the number?
Have you tried with dial assist turned off?
14-03-2022 07:52 AM
Hello James,
I’ve tried turning off Dial Assist, it makes no difference.
What happens? - I get three beeps and “the rest is silence”.
Geoffrey
14-03-2022 09:53 AM
Hi @gvs1
Thanks for coming back to us.
Have you tried connecting to a different network in your phone settings?
Does this happen with more than one number?
Leanne 🙂
