Roaming
Fkelly12021
Hi,  I've added an add on of 25 roaming data however still not able to use Internet. I'm currently in Turkey.
Can anyone help?
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
@Fkelly12021 : What is "add on of 25 roaming data"? If you mean the £25 pm Roam Abroad Pass, it is not valid in Turkey.
Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
