Roaming won't work in US even though I paid for the 30 roaming pass. I need help
pennyurell
@pennyurell  That roaming pass allows you to use your allowances while there that’s all it doesn’t enable roaming as that’s an account setting.   Did you text ROAM to 150 or call customer services to request roaming be enabled on your EE account?
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
