Roaming pass
Bob9991
Bought roaming pass for Canada, tried to active just before leaving uk , no luck , now stuck in Canada unable to receive calls or make calls to people I need to on this trip. Can’t find an email address to contact or anything. Please help
@Bob9991 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. How exactly did you try to activate before leaving the UK, and in what way did you get "no luck"?
On PAYG, roaming is auto-enabled once your phone is used in the UK first.
