Roaming pass usa not able to use data
Emmalaq
Help,
I have just arrived in usa, I sent the ro usa to 150. I was not covered. So bought the roaming further pass for £15. I log into my ee and I should have access to messages calls and data. The same allowance I have in the UK. The calls and messages work. But my data will not.
What have I missed ?
Christopher_G
OK, thank you, @Emmalaq.
Could you try toggling your data roaming off and then back on again in your phone settings please?
If that doesn't work, you may need to speak to our Mobile Care team so we can check everything from our side.
14 REPLIES 14
Christopher_G
Hi @Emmalaq
Welcome to the community.
Are you on contract or pay as you go?
@Emmalaq   Have you tried just restarting the device?
Hi Chris,
I am a pay monthly contract
Hi Chris,
Yes I have restarted my phone but still no luck?
Christopher_G
I know you activated an add-on, but did you activate the roaming feature before you went, @Emmalaq?
Hi Chris.
Yes I texted roaming to 150, it was not set up for the USA, so I bought the roaming further pass, I then texted roaming to 150 again and it said I was set up for roaming in any country.
Christopher_G
That's great, it must be set up then, @Emmalaq
Could you try manually selecting a US network carrier?
Hi Chris,
Yes I can go into network operators,
It gives me the options of
Version wireless
311490
T mobile.
It would not load t mobile do I connected to Version wireless.
I have note tried 311490 yet.
When I am connected to Version wireless it still comes up with no Internet connection when I try to use Google maps ?
Christopher_G
so, on Version, you're connected with a mobile signal, but the data side isn't working, @Emmalaq? Does it allow you to make a call?
What kind of phone are you using?
