18-10-2022 11:01 PM
I have two phones (Google Pixel 6 and Pixel 3a XL). They both have exactly the same settings enabled but the 3a states 'EE (temporarily unavailable)'.
Mobile data and Roaming are both enabled, and I have paid for ROW Roaming as an add on. However, the Pixel 3a cannot make it receive a call. It has no signal. I've reattached several times and waited a couple of days for this to 'kick in' as suggested by some on this forum.
No luck. I have been in the US for five days now and still don't have access to this phone (it's my mother's).
What do I need to do to get this working? The other phone works just fine.
Please don't tell me to call customer services as I am overseas and the hours are incompatible.
By adding the rinsing pack, I would have thought it was obvious that we were planning to use this overseas. I find this very frustrating.
Your help would be very much appreciated
18-10-2022 11:15 PM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
19-10-2022 02:28 AM
Thank you for the advice. I did not text Roaming to 150 before I left. I didn't know this was required.
I have rebooted the phone several times to no avail. I have tried manually selecting the network. No luck. I have also gone online to double check that roaming is enabled. It is.
Although I tried rifling it off/on just now, and now it appears to be stuck in the off position and I'm told to check back later. Infuriating!
19-10-2022 07:27 AM
Hi @JimJagger,
Which roaming add-on did you purchase?
Do you have a spend cap on your account?
19-10-2022 02:27 PM
It is the Roam Abroad Pass (£10 a month). Definitely no spend cap enabled.
19-10-2022 02:37 PM
Hi @JimJagger,
You should be good to go once we can make sure roaming is activated at an account level. Turning it off then on again several times may have caused a backlog of change requests on your account. I'd recommend contacting Customer Care who can access your account directly.
19-10-2022 04:57 PM
Now's the time to call CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
19-10-2022 05:29 PM
Thanks. I called this morning but they couldn't help. They're calling me back soon.
19-10-2022 05:30 PM
20-10-2022 12:23 AM
They said they would can back within 10-15 minutes, but I'm afraid nobody called back - and I have no way of contacting them without going through the convoluted phone call, followed by a text message and a call back. It's obviously out of hours now but that's six days without a working phone. Very disappointed.
