on 14-08-2022 07:14 PM
I have bought a roaming add on but it is not working
on 14-08-2022 07:28 PM
@sallycb : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
on 14-08-2022 08:40 PM
on 15-08-2022 07:43 AM
Hi @sallycb
Welcome to the community.
Have you tried restarting your phone or manually connecting to a different available network?
What is happening when you try to use it? Is it connected to a network with a mobile signal?
on 15-08-2022 03:50 PM
15-08-2022 03:58 PM - edited 15-08-2022 03:59 PM
Hi @sallycb,
What happens when you try to make a call, send a text or use data?
Which roaming add-on did you purchase?
on 15-08-2022 05:26 PM
15-08-2022 05:29 PM - edited 15-08-2022 06:21 PM
Have you checked your relevant MyEE settings like I said?
on 15-08-2022 05:29 PM
Hi @sallycb,
What happens when you try to make a call? Do you hear a recorded message?
