Roaming in USA
MrsLawson
Hello
I would like to confirm, one I text Roaming to 150 and get this added for £15 and switch on the Roaming in my settings, will I receive other charges while away or will this then cover everything?
Thank you
1 ACCEPTED SOLUTION
@MrsLawson    You can use your device like you was in the UK.     Enjoy the trip.
To clarify though, there's two elements to this
Roaming is not a phone setting that you can enable, it's a network setting that is done by texting ROAMING to 150 before leaving the UK, this enables access to foreign networks.
Your phone may have an option to enable data roaming - this simply means using mobile data whilst roaming. There isn't a phone setting to allow voice-call roaming or text-message roaming, but that would be the equivalent.
A billing add-on simply reduces the cost of roaming.
