02-12-2021 01:23 PM
Hi all,
I’m currently in Paris and I have tried to use my EE number but it was unsuccessful.
I only see the 3G I tried switch to 4G and 5G and even reset my network setting with No success.
i also contacted EE customer services and again no success.
I’m unable to call no receive msg at all.
can anyone suggest a solution.
thank you all
02-12-2021 01:25 PM
@Reemz : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu > Account Settings > Control Content > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
If not already enabled, you need to call CS to enable the Roaming Abroad and Call Abroad and Premium Rate settings of your MyEE.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything.
02-12-2021 01:43 PM
02-12-2021 02:19 PM
Hello @Reemz.
Welcome to the EE Community.
Are you able to connect to a local network?
Speak soon,
Katie.
02-12-2021 02:27 PM
Hello dear
yea I can connect to orange F, SFR and Bouygues telecom.
However the data doesn’t connect to 4G or even 5G, only 3G so Data doesn’t work + I can’t make or receive calls.
02-12-2021 02:41 PM
Thanks for letting us know @Reemz.
Have you topped up recently?
Are you aware of anyone else experiencing this issue?
Katie.
02-12-2021 06:23 PM
Yes I topped up my account + I bought a package but nothing worked out
03-12-2021 07:36 AM
Hi @Reemz,
When you were using the SIM in the UK, did you make a chargeable call or send a text?
08-12-2021 10:05 PM
Hi dear
yes I did make calls, now I left EU to Qatar and still my number is not working nor I can receive msg.
is their any solution to this? The network only shows 3G and I even tried to change the device and still the same issue.
please advise
08-12-2021 10:53 PM
Did you make chargeable calls or texts while in UK, not just from your pack? How long ago was that?
