Roaming not working in San Francisco
CathrynMarcus
Not sure if this is the right forum - there wasn't one for roaming. Mine was set up for me by EE with the £25 add-on charge. I have a Samsung galaxy A12. Roaming is on. Nada. Been here 3 days now. Plenty of bars of signal most of the time when I'm out and about, though no 4G it would seem. Two networks seem available- tmobile and version- but the only time my phone works is when it has access to WiFi. Why? Is it the case that there is just rubbish coverage in San Francisco for the networks that EE customers can use? If so, why sell me the £25 add-on?
This is the correct forum covering roaming as its header suggests.
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
