on 03-11-2023 11:03 PM
Is there a rule whereby , even with having the roaming abroad monthly, it will not work beyond a certain amount of time.
I have been using the roaming fixed monthly abd it has worked fine for 2 months in Germany. But suddenly have no data or sim connection.
Appreciate any insights.
on 03-11-2023 11:20 PM
If you're on pay-monthly, there is a a stable-links policy requiring usage in the UK for 2months out of 4 - but my understanding is that this is not a hard-stop as one where EE should get in contact first.
Have you tried using alternate local networks in Germany?
on 03-11-2023 11:24 PM
@Scottyjo : There is a Stable Link policy whereby to show you have a stable link with UK you should not spend more than 2 months outside UK in any 4 month period. However should you exceed that you are not cut off but a) asked for an explanation or b) charged a surcharge on your future usage abroad,
I recall sometime in the past there was a rule to do with how long a EE sim could be connected to a roaming network before it had to be back in the UK but can't find anything in current documentation.
Other thought is if you have set a limit to how much additional charges you can incur in your billing period and are being charged a daily fee for use then you could have exceeded it and resulted in phone and data not working.
EG EE charge £2.29 a day for usage in the EU (if no special plan) and I had to allow at least £20 as the minimum limit when my wife went on a whale watching cruise.
on 03-11-2023 11:33 PM
The stable links policy is listed on Page 2 of the current roaming T&C
