on 03-11-2023 07:14 PM
I have EE SIM Only “all rounder” plan which includes one inclusive add on..
if I choose the roaming pack, can you confirm
1. Does the pack activate immediately or at next billing cycle
2. Do I need to txt ROAM to 150 to activate Roaming on my account - OR - will be turned on by pack activation
3. Do I need to set min £20 spend cap - OR - with activation of my inclusive roaming pack, no spend cap required
4. If I say travel want to switch my inclusive add-on, can I do this ( I assume only one switch per billing cycle - is this correct )
on 03-11-2023 08:05 PM
on 04-11-2023 07:33 AM
Morning @Clever-Trevor
I can see you have had some great advice from @XRaySpeX, you can find tips on getting ready to roam in our Roaming Costs | Help | EE page.
Once you’ve chosen the inclusive extra, you can change this thereafter every 30 days.
Leanne 🙂
