Roaming in Canada, phone is useless
steve345
I'm currently in Canada, I forgot to set up roaming before I left. My phone will not pick up a signal or a network. I can't make calls, even to the EE number for assistance.
I have tried switching all the network buttons, off/on etc but nothing works. I need my phone to be running data at the least.
What is my next step?
6 REPLIES 6
@steve345 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
I’ll give the Skype number a go tomorrow. I’ve tried all the other options you’ve mentioned, nothing doing.
can’t even ring out to Customer Service.
Thanks for the help
steve345
Can’t get on Skype cos they send my code to my phone to unlock my Skype account. I’m losing business because of this. Can you not just ok my account through email or something? Frustrating lack of help on the website, live chat etc
No, we can't! This user discussion forum can have no access to your specific account. You need to raise this with CS.
As I said before; I cannot get in touch with CS as I have to have a signal to get the code that will allow me to use my Skype account. Live chat robot is infuriating and does not understand what I’m trying to do. The hours I am working out here only give me a small window in the morning to raise problems with CS even if I could get in touch. Is there an email address that I can have to get this sorted?
EE provide no email contact.
I installed Skype on a PC w/out needing a phone or codes sent to 1.
